Hymer GCS 4x4 from 225/75 to 245/75 R16 please HELP!
frederick fitzroy
Re: Hymer GCS 4x4 from 225/75 to 245/75 R16 please HELP!
Beitrag von frederick fitzroy »
frederick fitzroy hat geschrieben: 22 Feb 2025 09:45
MobilLoewe hat geschrieben: 22 Feb 2025 08:51
frederick fitzroy hat geschrieben: 21 Feb 2025 23:40
Do you mean that the Hymer GCS doesn’t have the correct code (RH8) for the 245/75 tires BUT just the 120kmh limitation ? :shock: :shock:
Yes
That’s insane. How did you discover it?
:?: Really I would Love to know how you have discovered.
Because if this is “standard” for Hymer, I will not bother myself for while about the RH8 code….
MobilLoewe
Beitrag von MobilLoewe »
frederick fitzroy hat geschrieben: 22 Feb 2025 09:45 :?: Really I would Love to know how you have discovered.
I was able to see all the codes via a VIN decoder.
frederick fitzroy
thank you!
Are here other like @mobilLoewe on Hymer 4x4 that had the same experience?
Lessol
Beitrag von Lessol »
frederick fitzroy hat geschrieben: 21 Feb 2025 23:38
Lessol hat geschrieben: 21 Feb 2025 22:08 The speed limit (MD3 ) results from the use of AT tires, with size 245/75R16, RH8 coding must be done because it is required for the correct operation of the speed and odometer, as well (most importantly) ESP and therefore 4ETS, as well as all other safety systems. Unfortunately, in the homologation of the Spinter 3.5 t this size is not included and therefore permitted (for emission reasons), nevertheless it can be coded because in the 4.1 (USA) variant it is a standard size.
So it means that I can not swap from 245/75 to 225/75 when I want ( for example, I go for a trip in which there are something like 1000km on the highway where 245/75 are not useful )...
I should go all the time back to MB?
If it is to be in accordance with the manufacturer's recommendations, you must visit a workshop. Fortunately, the difference in size between 225/75R16 and 245/75R16 is an error of about 4%, so the speedometer readings are not very large (at 100 km/h approx. 4 km/h), so there will be practically no big error because every speedometer lowers the reading. How ESP reacts on larger A/T tires in a critical situation, you can't predict that. Certainly, braking from high speed even on asphalt is not pleasant.
MB Sprinter W906 - 315 4x4 OA 6-Gang ; ZG4 ; R1-3250 - ZS; HA-QS; VA QS ; US i =2,85 ; UFS VA ; UFS VG ; 180PS ; 245/75R16
