front axle noise
nessie
front axle noise
Beitrag von nessie »
hi i have a 4x4 313cdi and when turning right i get a whining noise from the front right axle and now also slight noise from the left axle any ideas.
also when idiling at traffic lights and pulling away i have white smoke from exhaust for a few seconds i am not losing any coolant could this be my turbo on its way out.
many thanks from sunny scotland
david
Boogieman
Re: front axle noise
Beitrag von Boogieman »
"white" smoke doesn't sound like Turbo related . . oil is black/grey smoke, blue would be fuel . . but white is water, I wouldn't be concerned when you don't have to top up your cooling system . . could be condensation if it's only when driven in traffic and now when the temperatures get colder it will always smoke a bit white until it's warm . .
Aktuell besitzer von fünf 4x4 Sprintern . . falls sich jemand fragt wo die alle sind :D
Bobil
Beitrag von Bobil »
Hey,
i think it could be the bearing kit, if it changes the noise with curves. May be it would be good to test this. In my case, the right bearingkit does more noise when turning to the left side...
Andreas
