LT 35 diagnosestecker
Gast
Beitrag von Gast »
---Translated with babelfish---
Hallo!
waiss jemand der Stift Auftrag der Diagnosestecker in bj 2002 vw lt 35 ? (http://www.kolumbus.fi/hannu.hollmen/liitin.jpg)
mit diesem Adapter könnte ich das Auto mit VAG-COM diagnosieren. Adapter Kosten 80 €... :( (http://www.vag-com.se/img/adapter_LT_vag-com.se.jpg )
im OBD-II Stecker 4= masse 7=K 16= batt+
Best,
Hannu
Hi!
Does anyone know the pinout of the 15 pin diagnostic connector in VW LT?
With this adapter (http://www.vag-com.se/img/adapter_LT_vag-com.se.jpg)
it is possible to use the VAG-COM system to diagnose engine and immobilizer. I need to know the pin numbers of earth connection, K-line and positive battery. In OBD-connector in the picture above they are 4,7 and 16.
Gast
Re: LT 35 diagnosestecker
Beitrag von Gast »
Here is the pinout, if someone is interested...
(upper side of the connector when standing on the ground with driver's door open)
3 2 1
O O O
7 6 5 4
X O O O
11 10 9 8
X X X X
14 13 12
O O X
X= No connection (empty slot)
With interface, (working with VAG-COM) connect like this:
VW (obd) MB (LT)
4 (earth) 1 (KL 31)
7 (K-line) 14 (motorsteuer) (4) (wegfahrs)
16 (battery +) 3 (KL 30)
With this I cleared the faultcodes from engine and immobilizer with VAG-COM just fine. You may have to connect MB pin 4 (immo) to the pin 7 also, but I didn't have to. I could diagnose immo without pin 4 just fine.
