ich habe zwei Kartuschen Sika im Keller gefunden, bei denen vor 2 Jahren das Haltbarkeitsdatum abgelaufen ist.
Kann man die noch verwenden?
Jochen
Sika 554 Haltbarkeitsdatum
- MobilLoewe
Re: Sika 554 Haltbarkeitsdatum
Wenn das Zeugs sich noch gut verarbeiten lässt,.dann für weniger wichtige Arbeiten noch verwendbar. Für wichtige Verklebungen würde ich jedoch neue Kartuschen nehmen.
...wenn der überhaupt noch zu den Überlebenden gehört. Ich würde ihn nicht mehr verwenden.
nadabsardar
Hi Jochen,camper42 hat geschrieben: 14 Jul 2026 21:20 Hallo zusammen,
Jochen
Sika sealants (including 554) will usually still be usable a couple of years past the printed expiry date, provided the cartridges have been stored somewhere cool, dry and out of direct sunlight — a basement is generally fine for that.
Worth checking before you commit to using them on anything structural or watertight:
Consistency — squeeze a small amount out first. It should flow smoothly and evenly. If it's gone stringy, grainy, or won't extrude properly, it's had it.
Skinning time — a bead of fresh sealant should start forming a skin within 10–20 minutes (touch it lightly with a gloved finger). If it takes much longer than usual, or stays tacky/wet for hours, the curing agent has likely degraded.
Smell — it should still have that typical sharp, slightly vinegary/acetic smell (for acetic-cure types) or a milder smell for neutral-cure. A "dead" or flat smell can indicate it's no longer reactive.
Full cure test — do a test bead on some scrap material and leave it 24–48 hours. Check it's cured right through (not just skinned on the surface) and still has proper flexibility/adhesion when you try to peel or flex it.
If it passes all of that, it should be fine for general use. That said, for anything critical — roof seams, windscreen-adjacent areas, or places where a failure would let water in — I'd personally not risk two-year-out-of-date sealant and would just buy fresh cartridges. It's cheap insurance compared with the cost of chasing a leak later.
Hope that helps!
