Sprinter 906 4x4 Rear Axle problems A9063501804
MAK1990
Beitrag von MAK1990 »
Hopefully it is ok for me to write in Engslish since i am based in Norway.
But:
I have a Mercedes Sprinter 316/37 4x4 automatic 3,5 tonn 2016 modell VAN
My rear axle shafts needs to be shifted, but it seems to be difficult to find the right types.
On my Rear axle it stands:
typ: A9063501804
i = 46:11 I= 4,182
I have taken meaurements of the different shafts and they are:
Left 840mm
Tags wheelside 30
Tags differentialside: 29
Right 890mm
Tags wheelside 29
Tags differentialside: 30
I cant fint any who matches on the different types, could any one help me with the OEM number to the shafts from the axle A9063501804.
I tried many different sources, but is this a special axle since their are nearly no info in google etc.?
Really hope anbody can help me link to the right shafts for this one.
In advance thank you.
Regards,
Morten Andre Karlsen / Norway
f54
Re: Sprinter 906 4x4 Rear Axle problems A9063501804
Beitrag von f54 »
MAK1990 hat geschrieben: 31 Okt 2025 14:32 Hi,
But:
typ: A9063501804
i = 46:11 I= 4,182
Left 840mm
Tags wheelside 30
Right 890mm
Tags wheelside 29
Regards,
Hi Morten, thanks for joining us, your VIN would make it much more easier. Just replace the 3 digits with "xxx".
MAK1990
Hi, sorry
xxx9066331P297122
I have checked with Mercedes in Norway on the VIN, but as they find the wrong partnr and measurements i think maybe it could be changed to another type.
Therefore i added the OEM nr on the rear axle.
Morten
Instead of the Axles part number, please post the built number.
Could possibly start with an 741412 or 741415
MAK1990
Hi, yes i have this on.
Fz 741421-Z682300
Var 004070848
Thanks.
Driveshafts should be either
left side A9063502610 or A9063503910
Right side A9063502710 or A9063504010
https://mb-teilekatalog.info/view_SubGr ... subgrp=100
Axle oil should be 2.2liters 75w90 or 75w85 with MB approvel 235.8 or 235.31
f54 (31 Okt 2025 15:47)
