Sika 554 Haltbarkeitsdatum
camper42
Beitrag von camper42 »
ich habe zwei Kartuschen Sika im Keller gefunden, bei denen vor 2 Jahren das Haltbarkeitsdatum abgelaufen ist.
Kann man die noch verwenden?
Jochen
Re: Sika 554 Haltbarkeitsdatum
Wenn das Zeugs sich noch gut verarbeiten lässt,.dann für weniger wichtige Arbeiten noch verwendbar. Für wichtige Verklebungen würde ich jedoch neue Kartuschen nehmen.
camper42 hat geschrieben: 14 Jul 2026 21:20
iSika im Keller gefunden,
...wenn der überhaupt noch zu den Überlebenden gehört. Ich würde ihn nicht mehr verwenden.
nadabsardar
Beitrag von nadabsardar »
camper42 hat geschrieben: 14 Jul 2026 21:20 Hallo zusammen,
Jochen
Hi Jochen,
Sika sealants (including 554) will usually still be usable a couple of years past the printed expiry date, provided the cartridges have been stored somewhere cool, dry and out of direct sunlight — a basement is generally fine for that.
Worth checking before you commit to using them on anything structural or watertight:
Consistency — squeeze a small amount out first. It should flow smoothly and evenly. If it's gone stringy, grainy, or won't extrude properly, it's had it.
Skinning time — a bead of fresh sealant should start forming a skin within 10–20 minutes (touch it lightly with a gloved finger). If it takes much longer than usual, or stays tacky/wet for hours, the curing agent has likely degraded.
Smell — it should still have that typical sharp, slightly vinegary/acetic smell (for acetic-cure types) or a milder smell for neutral-cure. A "dead" or flat smell can indicate it's no longer reactive.
Full cure test — do a test bead on some scrap material and leave it 24–48 hours. Check it's cured right through (not just skinned on the surface) and still has proper flexibility/adhesion when you try to peel or flex it.
If it passes all of that, it should be fine for general use. That said, for anything critical — roof seams, windscreen-adjacent areas, or places where a failure would let water in — I'd personally not risk two-year-out-of-date sealant and would just buy fresh cartridges. It's cheap insurance compared with the cost of chasing a leak later.
Hope that helps!
