Help in Namibia.....A 901 997 00 47 metric dimensions
Hello everyone,
we are in Namibia with our 313cdi 4x4 sprinter and need this part A 901 997 00 47, we can not source it anywhere so does anyone have the metric sizes so we can get a replacement,
many thanks
David
many thanks
David
- kilian
Re: Help in Namibia.....A 901 997 00 47 metric dimensions
@ alle 4x4 Fahrer, oder die sich damit auskennen:
Helft mir mal, bitte:
Nessie sucht einen Dichtring für das Verteilergetriebe mit der Teilenummer s.o. und bekommt den nicht in Südafrika.
Soweit ich weiß, werden doch im 4x4 keine MB eigenen Getriebe verbaut?
Ist das nicht ein Getriebe aus dem Toyota HDJ 80 ?
Kann er dann nicht den Dichtring bei Toyota kaufen?
@nessie:
i think your gearbox is made by Toyota (HDJ80)
I asked other 4x4 drivers if they know more about it.
I hope i can give you answer soon.
Greetings, Kilian.
@nessie:
Greetings, Kilian.
Umbau von:
2,5 TDI AHD -> ANJ-Motor
Sperre hinten
Umbau von:
Sperre hinten
Hi David,
Here You can order it:
https://www.online-teile.com/mercedes-e ... tring.html
I don't know if they ship to namibia. There are also dimensions specified.
Reise: Offroad in Lettland
Hello thank you for the quick response,
we need the outside dimensions and the inside dimensions and the thickness, the 6cm x 6cm x 1 cm does not make sense to us
thanks
David
thanks
David
Hi David.
Part 52 ?
http://avtochast.ru/mercedes/bus/?regio ... up=080&p=2
I tried something, but it seems, there is no real chance to get the size :-/
Gruß, Uwe.
Part 52 ?
Gruß, Uwe.
I think 6cm is the outer diameter/ diameter of the housing.nessie hat geschrieben:... the 6cm x 6cm x 1 cm does not make sense to us
Many thanks for all the help, tomorrow we take off the prop shaft and the flange and measure the seal dimensions, it is probably the only seals i do not carry on my sprinter
Hello we have taken off the old seal and the dimensions are 72mm x 40mm x 10mm we only got a 72x40x8 mm seal but this should do.
we asked the mercedes technical department in the u.k and they emailed me back to say they did not know the size of their own parts
many thanks to the forum for your help
David
David
- joethesprinter
72x40x8 scheint ein exotisches Maß zu sein. Kann das jemand bestätigen?
Nö, scheint nicht exotisch zu sein: Wellendichtring / Simmerring BASL 40x72x8 mm, Wellendichtring / Simmerring BASL 40x72x10 mmjoethesprinter hat geschrieben: 07 Okt 2021 21:42 72x40x8 scheint ein exotisches Maß zu sein. Kann das jemand bestätigen?
- joethesprinter (08 Okt 2021 10:02)
- der.harleyman
Please take care due to the other dimensions. Don´t place it diagonally.nessie hat geschrieben: 05 Okt 2016 12:30 Hello we have taken off the old seal and the dimensions are 72mm x 40mm x 10mm we only got a 72x40x8 mm seal but this should do.
Take a good look to the shaft, before you place the sealing ring.
You have the lucky chance to place it with 2mm offset.
In case you will see a deep groove at the surface of the shaft, try to place the new ring
with offset, to get a new position of the shaft with a fresh and smooth surface.
Otherwise the new ring will fail again after a short time...
Nessies Anfrage ist jetzt 5 Jahre alt.der.harleyman hat geschrieben: 07 Okt 2021 23:06 Please take care due to the other dimensions. Don´t place it diagonally.
Aber trotzdem ein guter Hinweis
Nessie war vor vier Jahren das letzte Mal hier aktiv, seine Webseite ist seit 2017 in China, Guangdong angesiedelt, betrieben von einer "Foshan Noah Electric Co., Ltd". Da bei mir Scripte abgeschaltet sind, sehe ich dort nichts. Ist vielleicht auch besser so.
Übrigens, der Wagen sollte 2018 verkauft werden, hier ein paar Bilder. Ob der immer noch in Sambia zum Verkauf steht? Wer weiß?
- der.harleyman (08 Okt 2021 08:44)
- Sprinter_213_CDI
Und er war in Ecosse ( Schottland )
- joethesprinter
Mich würde dennoch die Auflösung des Problems interessieren. Falls ich aus Unkenntnis der originalen Dicke des Ringes den falschen bestelle wird es wohl zu dem Versatz kommen.Vanagaudi hat geschrieben: 08 Okt 2021 00:23Nessies Anfrage ist jetzt 5 Jahre alt.der.harleyman hat geschrieben: 07 Okt 2021 23:06 Please take care due to the other dimensions. Don´t place it diagonally.Ich hoffe, er braucht noch keinen neuen Dichtring.
- joethesprinter
Der Ring mit der angegebenen TNr. ist 8mm dick und hat einen Außendurchmesser von 60mm. Jetzt bin ich verwirrt.
